S32 IDE downloading problem
tony_huang
Hi, I used S32 IDE to download my project , but there is something wrong during downloading code.Is there anyone encounter this problem?
martin_kovar
could you please write me back, which version of S32DS you use? There is S32DS for ARM and S32DS for power, version 1.0 and 1.1. In case you use S32DS for power version 1.1, have you already install update 1?
https://community.nxp.com/docs/DOC-333045
I also need to know, what device you try to connect.
Have you correctly install PeMicro drivers?
Which debug probe you use?
Martin
tony_huang
Hi, I have found the reasons:There is something wrong with my circuit hardware design.
Thank you very much.
