We have multiple MPC5748G eval boards and are currently debugging software that utilises the HSM, we have an image of the HSM firmware however need to enable the HSM. I understand that the HSM is to be enabled via a DCF record however we don't have a copy of the HSM reference manual which details this. Please can I request a copy of this HSM reference manual?
FYI: we are building with GCC (powerpc-eabivle-gcc) and flashing the boards using the OpenSDA (micro usb) interface using the powerpc-eabivle-gdb server.
Many thanks,
Jamie
In order to get security reference manual first is necessary to submit a ticket.
https://community.nxp.com/docs/DOC-329745
Security RM is under controlled release and there is defined procedure in order to get hand on it.
regards,
Peter
