MPC5748G:how i can get flexray wakeup pattern?
515 次查看
helius0908
by used one board send wakeup pattern,i can see wakeup pattern in flexray bus
but,i can't get wakeup pattern in MPC5748G,
I had enable FR_WUPIF_IRQn,and set GIFER[WUPIE], however, IRQ don't trigger.
i also try other IRQ,such as FR_PRIF_IRQn, and i get trigger.
so, if i want get wakeup pattern, what i should set?
标记 (2)
483 次查看
lukaszadrapa
can you see if the WUPIF flag is set?
Lukas
407 次查看
helius0908
hi
i had solved it.
i set a wrong data in wakeupsymbolRxIdle.
thanks
