MPC5744P performance monitor
1,386件の閲覧回数
billie60
Hello!
I am trying to set a performance monitor interrupt in MPC5744P. So I want to check registers setting like PMGC register, PMLCa registers, or PMC registers. But I cannot see them in Registers view or EmbSys Registers view. Where can I check them? Can you help me? thanks!
best wishes
Xu
1,381件の閲覧回数
davidtosenovjan
Unfortunately, it is not possible to view it with S32DS debugging view.
Apparently the only solution is to use different debugger (for instance Lauterbach TRACE32 is capable to show them) or access to these registers SW way.
3 返答(返信)
1,382件の閲覧回数
davidtosenovjan
1,375件の閲覧回数
davidtosenovjan
There is an appnote for the feature.
https://www.nxp.com/docs/en/application-note/AN4341.pdf
An access is indirect with using of mfpmr and mtpmr instructions.
1,378件の閲覧回数
billie60
Hello! Thanks for reply. But can you tell me how to access them in software way? It will very useful for me.
Best wishes!
