MPC5744P-144DS Expansion Board
abhinand_rd
I am having MPC5744p based evaluation board, MPC5744-144DS (144LQFP Expansion board).
Can somebody tell me how do i mount the microcontroller on to the Holder on this board?
There are some tools provided with this board, Is there any document that explains how to mount the microcontroller on this Holder?
Abhinand
abhinand_rd
Hi Peter,
Thanks for the response.
In your board you are using BGA package microcontroller. I am having LQFP package microcontroller.
Is the procedure same for both, Should i simply place the microcontroller into this holder and start working?
I have attached images.
Abhinand
petervlna
Basically the answer is yes. But, please read first the:
https://www.nxp.com/docs/en/user-guide/MPC5744PEVB144UG.pdf
to ensure you have set the jumpers on board according to your needs.
regards,
Peter
petervlna
I am not sure if I understood you correctly.
But you just pick micro and place it into the socket. First pin on micro is marked with dot and there is small triangle on the board with U1 mark. Dot and triangle must match.
regards,
Peter
