Is it possible to read pwm signals in MPC5777C?
kerem01011
How to read pwm signals in MPC5777C microcontroller? Is there any application example, or code example?
petervlna
The example can be used this one as starting point:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-MPC5646C-eMIOS-frequency-measurement-CW2...
or you can use SPC5748G example from S32DS, the mode module is the same:
Peter
petervlna
Peter
kerem01011
thank you very much!
petervlna
Yes, it is possible.
For such purpose this chip offer:
1. eMIOS where you can use input capture mode (reference manaul :36.6.1 Unified Channel (UC))
2. eTPU whole signal processing unit
Peter
