Hello NXP team,
I want to know which Inverter board is compatible to use with MPC5777C evaluation board. [if one intends to use MPC5777C board, which inverter board can be used with it] like MPC5744P with DEVKIT-MOTORGD.
Thank you in advance,
Solved! Go to Solution.
So you are asking which inverters are compatible with MPC5777C PCIE card.
With this one:
It is pin compatible with the following products:
Peter
thanks Peter, what is the name of the inverter board in the figure you sent?
With this one:
Peter
Thank you, Peter. So, what is the name of this inverter board in the figure you sent?
Here is the link:
Peter
