How to enable Peripheral Clocks (DMA0_CLK) using PE/ClockMan in S32ds/MPC5748G?
jzhang
Hi!  I am trying to enable several Peripheral Clocks following some SDK examples (s32ds+MPC5748G), and got stuck in the clock configuration.   I can't enable DMA0_CLK in DRUN mode in PE clockMan.  It shows "Configure clock gating.  Enables/Disables modules in the specified Power mode".   But I don't know how.  Could someone please help? Thanks!
Charlie
PetrS
DMA clock cannot be gated off.
You can refer to MC_ME_PCTLx registers in MC_ME memory map within device Reference Manual to know which modules allow this.
BR, Petr
jzhang
Hi Petr,  Thanks for your help!  I briefly read MC_ME in RM Chapter 38, but still don't know how to proceed.
I am trying to create a new project following the SDK lwip_MPC5748G example.  In this SDK example, clockman/DRUN configuration,  DMA0_CLK is enabled (grayed) at 80MHz, ENET0_CLK is ENET_RMII 50MHz.   But I can't make the same clockMan configuration in my created project.  My created project can be built without errors, but DEVKit board can't be pinged.   I attached my created project.  Could you please help?  Thank a lot!
Charlie
