How do I verify that the MPC5744P FPU is working properly
590件の閲覧回数
Edison_LI
I would like to know if the MPC5744P floating point unit is enabled?
I refer to some posts and set my S32DS to look like the following, is this correct? And how do I select the appropriate libraries supports
Thanks~!
Best regard,
Edison_LI
581件の閲覧回数
davidtosenovjan
Yes, it is correct.
'Use hardware floating point' enables EFPU instruction. If you need vector SIMD instructions (LSP) you will have to choose proper option in 'Signal processing menu'.
2 返答(返信)
582件の閲覧回数
davidtosenovjan
Yes, it is correct.
573件の閲覧回数
Edison_LI
Now I think FPU is indeed turned on.
Thank you for your reply!
Best regard,
Edison_Li
