Hardware Floating Point Unit Enable Method
883 次查看
santhana_g
Hi NXP,
We are using MPC5746C controller for our project. We need to enable the Hardware Floating Point to do floating point operation in our project.
Could you please guide us, how to enable the Hardware FPU and steps to verify?
Note: We are using GHS compiler.
Thanks in Advance
764 次查看
petervlna
For usage of floating point see the core reference manual:
Could you please specify what are you requesting?
regards,
Peter
764 次查看
santhana_g
Thanks for the information.
I will follow the above steps.
I need more information regarding the testing part.
How to verify, this feature is enabled and reduced the processing time?
Thanks in Advance
764 次查看
petervlna
Simply execute some FPU instruction. If it is no enabled the micro will throw exception.
regards,
Peter
