FreeRTOS- like OS for MPC5634M on CW Classic IDE
934 次查看
arjunraveendran
I am working on MPC5634M platform on Code warrior 2.7 Classic IDE. I know there is no ready made support from FreeRTOS for this chip.
Could anyone suggest an alternate RTOS which supports this chip that i can port for my application?
Thanks in advance.
标记 (2)
4 回复数
693 次查看
petervlna
AUTOSAR OS is for sure supporting MPC5634M.
You can also use ARC CORE.
ARCCORE - AUTOSAR Products
For more details you have to ask ARCORE as this is not NXP product.
Peter
693 次查看
arjunraveendran
Thanks for the reply. Currently, I am not looking for a commercial licensed solution.
Could you point towards any free/open source options.
Thank you.
693 次查看
jfrey
ChibiOS has worked on e200 cores in the past.
The developer works for STMicro.  The topic has been brought up to support the newer NXP chips now that there is a free compiler available.
693 次查看
arjunraveendran
Thanks a lot for the answer.
I will check the compatibility with ChibiOS .
