When I using GreenHills to build file hello+pll_Z2_3 (samples code) , I get an error as Subject.
It's occur in file MPC57xx__Interrupt_Init.c, and detail as below:
"..\hello+pll_Z2_3\src\MPC57xx__Interrupt_Init.c", line 102: error #29:
expected an expression
uint16_t coreId = GetCoreID ();
"..\hello+pll_Z2_3\src\MPC57xx__Interrupt_Init.c", line 137: error #29:
Help me, Thanks !!
解決済! 解決策の投稿を見る。
I see.
This example package expect using of S32 Design Studio IDE.
For GHS compiler we have prepared lot of examples here on the community space:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC5-software-example-list/ta-p/1102445
Hope it helps
Hi, could you point out where the example is taken from?
Hi David,
I get this source from link: https://www.nxp.com/document/guide/get-started-with-the-devkit-mpc5748g:NGS-DEVKIT-MPC5748G#title4_1
I see.
Hope it helps
I download Example MPC5748G Flash RW GHS614 from your link.
But when I using command line "gbuild -top MPC5748G-Flash_RW-GHS614.gpj", cmd show Error:
[elxr] (error #21) cannot find library -lmulti
I attach image of an error. Thank you !
Unfortunately I cannot answer to this. I can open it correctly on my side. I have installed MULTI v7.1.4
Please contact GreenHills support:
