Hello Sir,
Yesterday, I received Calypso 3M 0N84S product, but I couldn’t attach through laughterbach.
According to the Calypso 6M 0N78S comparison, it’s JTAG ID has been changed, so I think also the Calypso 3M has been changed it’s JTAG ID.
Anyway, is this JTAG ID difference can make JTAG un-attachable?
If so, how can I fix it?
Neo
Solved! Go to Solution.
Yes this is possible.
You can contact Lauterbach support, and I will also notify them.
Peter
JTAG ID 0x0988501D is Calypso 3M. That chip is also supported already with PLS tools, if you need urgently some alternative you may contact them on www.pls-mc.com
Here is error log comes from Laughterbach.
debug hardware configuration error
JTAGID=0x0988501D
Processor with JTAGID 0x0988501D not supported by this debugger software version.
Get the latest software update from http://www.lauterbach.com/update.html and
try again. If the problem persists, contact support@lauterbach.com to request
a software update for your device.
JTAGID=0x0988501D
debug port fail
JTAG error: tdo always zero
debug port fail
debug port fail
JTAGID=0xFFFFFFFF
debug port fail
Do you have latest update from Lauterbach?
Here you can find updates:
Otherwise we must inform lauterbach.
Peter
Hello Peter,
Still it fails, maybe latest update from Lauterbach web doesn't support "JTAG ID = 0x0988501D"
Neo
Peter
