Unable to sprintf float value with redlib(semihost-nf)
2,157件の閲覧回数
akimata
I'm struggling to sprintf a float value with redlib(semihost-nf). What i've done:
- set PRINTF_FLOAT_ENABLE=1
- set SCANF_FLOAT_ENABLE=1
- removed CR_INTEGER_PRINTF
Example code:
char text_buffer[64]
snprintf(text_buffer, sizeof(text_buffer), "declination: %.2f\r\n" , 5.25);
Any ideas what else might be wrong?
It's working on newlib(semihost) but semihosting on that lib is just too slow and i would rather to stay on redlib.
7 返答(返信)
2,011件の閲覧回数
akimata
That's what i got in the settings. The weirdest part is that i created new project and it's working just fine there, but i cannot get it to work on my project so i just generated whole new project and copied files there and problem solved!. Still have no clue why didn't it work on my last project tho.
2,012件の閲覧回数
zhiqunhu
Try to remove CR_INTEGER_PRINTF in Preprocessor configuration.
2,012件の閲覧回数
ErichStyger
Senior Contributor V
could it be that you changed something in the linker settings? I would compare those.
2,012件の閲覧回数
ErichStyger
choose a different redlib library. nf means 'no-float'.
2,012件の閲覧回数
ErichStyger
correction: nf means no-files (not no-float)
2,012件の閲覧回数
akimata
I tried also redlib(semihost) and redlib(semihost-mb) and noone of them works.
2,012件の閲覧回数
ErichStyger
this is what I have:
