I imported lvgl from the SDK manager, but no files in the lvgl/examples/porting. These files are actually in this path.
Solved! Go to Solution.
You have to enable the content.
For example, following the available instructions in the lv_port_disp_template.c and lv_port_disp_template.h files, you should be able to see something like this:
Could you please try the instructions of the files to enable the content?
I hope this helps, Daniel.
Thank you!
