Problem with internal builder
465件の閲覧回数
biafra
Senior Contributor I
Hi everyone,
I'm facing a problem with MCUXpresso 11.9.1.
For some reasons in building my project I need to do some other things when I compile, so I created a script that do all I need (build + other things).
In the MCU C Compiler section I set my script as command builder. The script is located in the same folder as the project:
My scripts is working fine: when I build my project using the external builder, every project file is built using my script and the linker process is executed fine.
The problem arises when I need to build a single file: I launch the Build Selected File(s) command and I receive some error messages.
The first time I launched the command the message was:
Info: Internal Builder is used for build
"..\\mybuild.sh" -D__REDLIB__ [...] -o "source\\MIMXRT1064_Project.o" "..\\source\\MIMXRT1064_Project.c"
Cannot run program "..\mybuild.sh": Launching failed
Error: Program "..\mybuild.sh" not found in PATH
PATH=[C:\nxp\MCUXpressoIDE_11.9.1_2170\ide\plugins\com.nxp.mcuxpresso.tools.win32_11.9.1.202402080819\tools\bin;C:\nxp\MCUXpressoIDE_11.9.1_2170\ide\plugins\com.nxp.mcuxpresso.tools.win32_11.9.1.202402080819\buildtools\bin;C:\nxp\MCUXpressoIDE_11.9.1_2170\ide\plugins\com.nxp.mcuxpresso.tools.bin.win32_11.9.1.202402080819\binaries\;C:/nxp/MCUXpressoIDE_11.9.1_2170/ide//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_17.0.7.v20230425-1502/jre/bin/server;C:/nxp/MCUXpressoIDE_11.9.1_2170/ide//plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_17.0.7.v20230425-1502/jre/bin; [...] C:\nxp\MCUXpressoIDE_11.9.1_2170\ide]
Reading the error message I've found that the script folder wasn't in the PATH. So I modified the PATH environment variable to include that folder:
With these settings I receive a different message:
"C:\\...\\MIMXRT1064_Project\\mybuild.sh" -D__REDLIB__ [...] -o "source\\MIMXRT1064_Project.o" "..\\source\\MIMXRT1064_Project.c"
Cannot run program "C:\...\MIMXRT1064_Project\mybuild.sh": Launching failed
I receive the same error messages if I use the internal bulder in the global build process.
So it seems that the problem is bound to the internal builder.
Does anyone can help me in making the single file build process work?
Many thanks
Biafra
2 返答(返信)
423件の閲覧回数
ErichStyger
Senior Contributor V
418件の閲覧回数
biafra
Hi @ErichStyger,
Many thanks for your useful article.
In your article you say "One solution is to escape such characters". This would be the best solution for me, but I don't know how to do it. Can you give me some advice about it?
Many Thanks
Biafra
