有一个用MCUXpressoIDE建立的MKV46F256xxx16项目,在building是产生错误,提示丢失fsl_smc.h文件,如附图:
根据提示,这是一个与时钟配置有关的文件,按照我的理解,时钟配置好后这个文件应该自动加载,而我的时钟配置并没有提示错误,:
想手动加载这个fsl_smc.h文件,但是在MCUXpresso IDE和SDK的安装目录中,没有找到这个文件, 哪位碰到同样的问题能不能帮帮我? 多谢!
Qimin Liu
click on that icon in the toolbar, then add the smc driver to your project:
I hope this helps,
Erich
Hello qimin liu ,
In default , the file "fsl_smc.h" is under drivers folder when create a new SDK project.
Please re-create a new project to check whether you delete it by accident.
If still have issue , please use the latest SDK version 2.5 to have a try.
Hope it helps,
TIC
