MCUXpresso Unable to load SDK update site or SDK update site not set.
lucasmoraeseng
Hello everyone!!
I'm facing a problem with my MCUXpresso v11.2.1 (Build 4149). It's not find the update site to download sdk to install. My network is full of protections and I cannot disable all.
I would like to know what connection the software makes, because neither in my server log is showing a error.
I changed the sdk configuration, but didn't work neither.
Thanks so much.
Best Regards.
Lucas Moraes
MonJul
I have this issue too. What is the fix?
diego_charles
Hi @MonJul
As my colleague Libor, mentioned,  If you network is full of security things, it is possible that the  firewall intercepts the HTTPS communication, leading to this issue.
Could you help us to create a new thread describing your security settings, pasting  <workspace>/.metadata/.log file and specifying  your MCUXpresso IDE version ? If you like you could make reference to this thread.
Diego
MonJul
my network doesn't have any particulars safety since it's a home network.
My version of MCUxpresso is 11.3.1_5262.
Here is my logfile: https://drive.google.com/file/d/1EpsCGWsujvqqeWMSEIbJWZpr5ondhJWi/view?usp=sharing
liborukropec
your log seems *exactly* when someone is intercepting your connection. It might be a firewall/antivirus solution. Could you try to temporarily disable it before downloading the SDK/data?
Also if you have by accident openssl installed on your pc, could you try to run:
openssl.exe s_client -showcerts mcuxpresso.nxp.com:443 </dev/null
I have this, and if you have something different, we have a culprit:
depth=2 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert Global Root CA
verify return:1
depth=1 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = GeoTrust RSA CA 2018
verify return:1
depth=0 C = US, ST = Arizona, L = Chandler, O = "NXP SEMICONDUCTORS USA, INC.", CN = www.nxp.com
verify return:1
CONNECTED(00000004)
Certificate chain
0 s:C = US, ST = Arizona, L = Chandler, O = "NXP SEMICONDUCTORS USA, INC.", CN = www.nxp.com
i:C = US, O = DigiCert Inc, OU = www.digicert.com, CN = GeoTrust RSA CA 2018
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
1 s:C = US, O = DigiCert Inc, OU = www.digicert.com, CN = GeoTrust RSA CA 2018
i:C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert Global Root CA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Server certificate
subject=C = US, ST = Arizona, L = Chandler, O = "NXP SEMICONDUCTORS USA, INC.", CN = www.nxp.com
issuer=C = US, O = DigiCert Inc, OU = www.digicert.com, CN = GeoTrust RSA CA 2018
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 4221 bytes and written 410 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 2048 bit
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
DONE
Libor
liborukropec
look or paste here the <workspace>/.metadata/.log file . If you network is full of security things, it is possible that your firewall intercepts the HTTPS communication, providing company's certificate which is not trusted by Eclipse/Java, because Java has its own list of trusted authorities and do not rely on the OS list.
Libor
diego_charles
Hi @lucasmoraeseng
I hope you are doing well!
As you mention security features in your network, I am tempted to think that the firewall may be blocking the TCP port being used by the IDE to fetch an SDK from the SDK repository. Let me check internally for feedback.
In the meantime, we can try sort this issue by doing a drag and drop installation of your required SDK. Please check if you are able to acces to the MCUXpresso SDK builder using your web browser.
If you sucess, please refer to the MCUXpresso user guide chapter 4.2.3 Obtaining and Installing an SDK via SDK Builder.
I will  mantain you informed,
Diego.
Edit: re-phrasing
diego_charles
Hi @lucasmoraeseng
I have received early  feedback, Please try to do a click in the Refresh button. This will  force a reset of the cached contents in the SDK repository.
Let me know your results,
Diego.
