MCUXPRESSO IDE OPEN PROBLEM
1,472 次查看
aravindpb5009
Hai ,
          when i try to open the MCUXPRESSO IDE some error showing in my display , please let me know the solution for the problem , please find my below attachment what error was appeared in my pc
Thanks & regards
Aravind P
1,367 次查看
BlackNight
Hi Aravind,
could you share that .log file?
Erich
1,367 次查看
aravindpb5009
!SESSION 2019-08-20 10:07:17.040 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_181
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_IN
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Users\sabari\Documents\MCUXpressoIDE_10.3.1_2233\workspace\.metadata\.bak_0.log
Created Time: 2019-08-20 10:07:18.179
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:07:18.179
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (215).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:442)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: org.eclipse.core.internal.resources.ResourceException: Incompatible file format. Workspace was saved with an incompatible version: 0.
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:59)
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:67)
at org.eclipse.core.internal.resources.SaveManager.restoreTree(SaveManager.java:1056)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:719)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1587)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2399)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2156)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:467)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
... 29 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:07:18.209
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (215).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:112)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 22 more
... 29 more
!SESSION 2019-08-20 10:13:01.245 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:13:02.322
!STACK 0
... 29 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:13:02.344
!STACK 1
... 13 more
... 22 more
... 29 more
!SESSION 2019-08-20 10:29:03.798 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:29:04.877
!STACK 0
... 29 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:29:04.907
!STACK 1
... 13 more
... 22 more
... 29 more
!SESSION 2019-08-20 10:37:16.822 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:37:18.320
!STACK 0
... 29 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-08-20 10:37:18.347
!STACK 1
... 13 more
... 22 more
... 29 more
1,367 次查看
BlackNight
It looks like you are opening an incompatible workspace folder: try with a fresh new workspace or delete your current .metadata folder.
I hope this helps,
Erich
