Report one issue: J-Link probe couldn't be discovered
daweiyou
Hi Support:
While update opensda firmware from segger to FRDM-KE15, the board could support J-Link probe, but the IDE couldn't discover the jlink thru double click "GDB SEGGER interface Debug" to create one item. The IDE will report the debug configration is wrong, promote to delete.
Only start from quick start panel"debug your project"->"Jlink icon" to start debug, please check.
BlackNight
I recommend that you do not create a new launch configuration manually in the Launch configuration dialog.
Instead, let the IDE create a new configuration by pressing that icon in your last dialog.
That way all enries and fields in the launch configuartion will be set correctly.
If you do it manually, you would need to know exactly what you need to do.
I hope this helps,
Erich
