Hi there,
I'd like to use my LPC-Link 2 probe on the command line to program my boards and I cannot make it work this way.
First up, I launch "boot_link2" which works:
laci@spark /usr/local/mcuxpressoide-10.0.0_344/ide/bin $ ./boot_link2
/usr/local/mcuxpressoide-10.0.0_344/ide/bin/dfu_boot -s ./boot_link2 -n LPC-Link2 -v 0x1fc9:0x000c -i /usr/local/mcuxpressoide-10.0.0_344/ide/bin/../bin/LPC432x_CMSIS_DAP_V5_182.bin.hdr
Looking for DFU devices with VID 1fc9 PID 000c ...
dfu-util -d 1fc9:000c -c 1 -i 0 -t 2048 -R -D /usr/local/mcuxpressoide-10.0.0_344/ide/bin/../bin/LPC432x_CMSIS_DAP_V5_182.bin.hdr
Booted LPC-Link2 (1fc9:000c) with /usr/local/mcuxpressoide-10.0.0_344/ide/bin/../bin/LPC432x_CMSIS_DAP_V5_182.bin.hdr
Second, I launch "redlinkserv --telnetport=3025,3050" which starts up, but doesn't output anything and doesn't return. It also doesn't make the upcoming "crt_emu_cm_redlink" command work, and it hangs forever.
Third, I launch "crt_emu_cm_redlink", which fails. I assume it's because redlinkserv failed.
laci@spark $ /usr/local/mcuxpressoide/ide/bin/crt_emu_cm_redlink --flash-load-exec "/home/laci/download/uhk-left.bin" -g --debug 2 --vendor NXP -p MKL03Z32xxx4 --load-base=0 -ProbeHandle=1 -CoreIndex=0 --reset vectreset -x /home/laci/mcuxpresso/.mcuxpressoide_packages_support/MKL03Z32xxx4_support --flash-dir /home/laci/mcuxpresso/.mcuxpressoide_packages_support/MKL03Z32xxx4_support/Flash
Ns: MCUXpresso RedlinkMulti Driver v10.0 (Mar 21 2017 01:36:19 - crt_emu_cm_redlink build 190)
Pc: ( 0) Reading remote configuration
Pc: ( 5) Remote configuration complete
Nc: Reconnected to existing redlink server (PID 4294967295)
Nc: Connecting to probe 1 core 0 (server PID unknown) gave 'Ee(38). Invalid probe index.'
Nc: Server OK but no connection to probe 1 core 0 (after 3 attempts) - Ee(38). Invalid probe index.
Ed:02: Failed on connect: Ee(38). Invalid probe index.
Et:31: No connection to debug probe
Pc: (100) Target Connection Failed
"crt_emu_cm_redlink" works after I start up the Link Server GUI Flash programmer utility of MCUXpresso IDE, but as I said, I'd like to use LPC-Link 2 purely from the command line, so it's not an option.
Waiting for your ultimate wisdom, guys.
- Laci
解決済! 解決策の投稿を見る。
You should have a look a the 'LinkServer' (see https://mcuoneclipse.com/2023/05/14/linkserver-for-microcontrollers/
I hope this helps,
Erich
I hope this helps,
Erich
Hello All,
This is old thread, someone must have a solution by now....
I am in the same situation...
If I start the redlinkserver from the IDE by clicking the Red Link, then I can flash my MCU from CMD using crt_emu_cm_redlink.
If the server is not running then it fails with the following error:
Ns: redlink server client - failed to connect to new server localhost port 3490
Nc: Could not connect to link server - status 255
Nc: Failed to connect a LinkServer process.
Ed:02: Failed on connect: Ee(D0). Could not connect to server
Et:31: No connection to chip's debug port
One thing that is different here is the port number, when the server is started from IDE it connects to port 3025.
How can I make this work ?
Satbir
What is your command line that is failing?
have you checked firewall?
Thanks for the quick reply!!
Here is my cmd
crt_emu_cm_redlink -pMKE02Z64xxx4 -ConnectScript ke0xconnect.scp --flash-driver= -x --flash-dir -x -vendor=NXP -flash-load "code.axf"
Ns: MCUXpresso IDE RedlinkMulti Driver v11.2 (Sep 22 2020 13:23:35 - crt_emu_cm_redlink build 19)
Wc(03). No cache support.
Nc: Found part description in XML file MKE02Z4_internal.xml
Nothing pops up in firewall, asking for access.
And it works if I first start the Link Server from IDE.
Satbir
Hi @converse ,
I was having issues with RedlinkServer crashing, but I figured it out today.
redlinkserve.exe was crashing, because I didn't have the Scripts folder with the .exe file.
Once I moved the Scripts folder, it started working as expected.
Now, I have a working standalone GUI which can Unsecure/Flash the MKE02Z MCU with LPC-Link2.
Thanks for the reply!!
I have another question though!
Ns: MCUXpresso IDE RedlinkMulti Driver v11.2 (Sep 22 2020 13:23:35 - crt_emu_cm_redlink.exe build 19)
Nc: Restarted LinkServer process (PID 51348).
Wc: ============= SCRIPT: ke0xconnect.scp =============
Wc: KE0X Connect Script
Wc: Probe Handle 1 Open
Wc: DpID = 0BC11477
Wc: Assert NRESET
Wc: Reset pin state: 00
Wc: Power up Debug
Wc: APID = 0x04770031
Wc: MDM-AP APID: 0x001C0020
Wc: Release NRESET
Wc: Reset pin state: 01
Wc: MDM-AP System Reset/Hold Reset/Debug Request
Wc: MDM-AP Control: 0x00000008
Wc: MDM-AP Status (Flash Ready) : 0x00000007
Wc: Part is secured
Wc: Mass Erase Required
Wc: ============= END SCRIPT ==========================
Nc: Probe Firmware: LPC-LINK2 CMSIS-DAP V5.361 (NXP Semiconductors)
Nc: Serial Number: BSEWGYEQ
Nc: VID:PID: 1FC9:0090
Nc: USB Path: \\?\hid#vid_1fc9&pid_0090&mi_00#7&f75d0ea&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Nc: Using memory from core 0 after searching for a good core
Ns: redlink server client - failed to receive response (to op 62) from server after 2000ms - Unknown error (rc 138)
Nc: connection failed - EE(47): Debug Mailbox Request Failed... Retrying
Nc: probe 1 TAP 0 gives zero TAP ID - is probe connected to a target?
Ns: redlink server client - warning - 28 bytes of unexpected data from the server
Ed:02: Failed on connect: EE(47): Debug Mailbox Request Failed.
Et: Probe(0): Connected&Reset. Was: NotConnected. DpID: 00000000. CpuID: 00000000. Info: <None>
Nc: Last stub error 0: OK
Nc: Last sticky error: 0x0 AIndex: 0
Nc: Debug bus selected: MemAp 0
Nc: DAP Speed test unexecuted or failed
Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Nc: error closing down debug session - Nn(05). Wire ACK Fault in DAP access
Is there anyway to just run the Script with crt_emu_cm_redlink.exe, such that only the "italicized" portion of the above log is observed?
Can the crt_emu_cm_redlink.exe exit after running the Script?
Satbir
The error you are seeing is indistinguishable from that seen if there was no connection to a board/MCU.
Therefore I think it is time to take a big step back and establish exactly what is working ...
You are debugging using an LPC-Link2 debug probe and trying to connect to a board containing a KL03 MCU?
Is this a development board e.g. a Kinetis Freedom board or a user designed board?
How is the board being powered?
Are you able to debug this board from the IDE? If so, please can you paste the debug log for a successful debug session into this thread.
To find the debug log please go to the IDE Console -> From the Drop Down -> Debug messages
Yours,
MCUXpresso Support
Sorry to hi-jack this thread but my problem is related to the one above.
I'm writing a script to download the same firmware to three CPUs at the same time (to speed up production) using LPC-link 2's. Problem is that I can't get the script to work when using -ProbeHandle=n. If I run the script without the -ProbeHandle the CPU connected to the first LPC-Link 2 gets programmed three times. How do I get this to work?
Kind regards
Jimmy
Ps. If i run redlinkserv.exe --commandline and there do a probelist I see all the probes, indexed 1, 2 & 3. They are all running LPC-Link-II CMSIS-DAP firmware (And strangely enough have the same serial: A000000001).
The probes both works fine from MCUXpresso
They are programmed with the LPC-Link-II CMSIS-DAP firmware and set in the NON-DFU mode with the JP1 jumper in place (So if I understand it correctly no bootloading should be needed)
This link describes how to use the command line flash tool
https://community.nxp.com/message/630785
A couple of things to note:
- do not start redlinkserv. The tool automatically does this in the background
- if there is one probe connected to one mcu, do not use probehandle or coreindex
Hi Con,
I appreciate your answer, and already read the resources you linked before, but they're overly general, and lack detail. Unlike Segger J-Link, LPC-Link2 looks very command line unfriendly, and I cannot make it work based on these documents.
If I don't call redlinkserv when using crt_emu_cm_redlink, then I get:
Nc: Connecting to probe 0 core 0 - Ee(D1). Redlink server process restart
Nc: Server OK but no connection to probe 0 core 0 (after 3 attempts) - Ee(36). Could not connect to core.
Ed:02: Failed on connect: Ee(36). Could not connect to core.
I tried to run crt_emu_cm_redlink without the ProbeHandle or CoreIndex arguments and nothing seemed to change.
Any further help is much appreciated.
- Laci
Hi Laci
A very good idea.
In the following:
we would expect a failure because zero is not a valid probe number.
Omitting both the --probehandle and the --coreindex options will normally work best if there is no instance of MCUXpresso IDE in use.
The link server will be run for you if necessary.
It looks like you are trying to program the flash and are starting from the command line
which you probably derived from the command used inside the IDE. Here are some points that might help
If you don't need -x and you would like only to program the flash you could try:
/usr/local/mcuxpressoide/ide/bin/crt_emu_cm_redlink --flash-load "/home/laci/download/uhk-left.bin" -p MKL03Z32xxx4 --load-base 0
The existing information about using the tool from the command line is poor and we are thinking of updating it.
Meanwhile I hope the above will help.
Note also that
/usr/local/mcuxpressoide/ide/bin/crt_emu_cm_redlink -h
will print out some limited, if cryptic, details of some of the other options.
Sincerely
LPCXpresso IDE Support
Dear LPCXpresso IDE Support,
Thank you for the detailed description. I appreciate it very much.
Based on your description, I tried to strip down my command as much as possible, but unfortunately I get almost the same error messages as before:
$ /usr/local/mcuxpressoide/ide/bin/crt_emu_cm_redlink --flash-load /home/laci/download/uhk-left.bin -p MKL03Z32xxx4 --load-base=0 -x /home/laci/mcuxpresso/.mcuxpressoide_packages_support/MKL03Z32xxx4_support
Ns: MCUXpresso RedlinkMulti Driver v10.0 (Jun 22 2017 23:34:07 - crt_emu_cm_redlink build 272)
Nc: error closing down debug session - Em(02). MEM-AP is not selected.
Do you have any further ideas about this?
- Laci
We ran into a similar problem and found the solution. What worked for us was removing the "-ProbeHandle=1" parameter from the "crt_emu_cm_redlink" command, so that the probe is detected automatically.
I hope this helps :smileyhappy:
Enrique
