How to import CMSIS-DSP examples?
2,308 次查看
jerrylian
Inside MCUXpresso-IDE:
* when we click "Import SDK examples", we see many examples but not DSP examples!
* I check folder: ........\SDK_2.2_TWR-K60D100M\CMSIS\DSP_Lib\Examples
--- I saw *.uvoptx/.uvprojx files
So, can we import DSP examples in MCUXpresso-IDE? or we need to use Keil uVision?
Thanks!
Jerry
1,772 次查看
Hello Jerry,
You can install Keil to run the DSP examples,
or if you want use MCUXpresso IDE, please refer to the below DOC to use CMSIS-DSP,
it introduce the steps on kds, while it is the same with MCUXpresso IDE.
Adding CMSIS-DSP Library to a KSDK 2.x project in Kinetis Design Studio
Hope it helps
TIC
1,773 次查看
Hello Jerry,
Hope it helps
TIC
1,772 次查看
jerrylian
Hi Alice:
I followed your instructions:
* now I import DSP examples into MCUXpresso-IDE successfully.
* And it also solves my another problem of "hard fault".
Thanks a lot!
Jerry
