Hello World and Blinky Demo Apps won't Prog/Debug in Xpresso IDE v11.1.1, But Work Fine in Xpresso IDE v11.0.1
1,022 次查看
gregs5451
I'm using the unmodified demo apps for the FRDM-KE02Z40M board.
Errors:
Debugger Console tab:
monitor selectcore 0
"monitor" command not supported by this target.
continue
The program is not being run.
Console tab:
P&E Semihosting Console
Connection closed by the GDB server.
<Device is being erased and programmed and runs OK standalone, but will not run from debugger connection.>
UPDATE CORRECTION: Device is NOT getting erased OR programmed with Xpresso IDE v11.1.1.
Console info:
     IDE v11.0.1.        IDE v11.1.1.
What's the problem?
2 回复数
880 次查看
gregs5451
Hi Luis,
I have contacted PEmicro support. Based upon the information I sent them, they confirmed that there seems to be a problem (drivers maybe?), although they could not confirm with my specific FRDM board.
They requested more specific information which I just sent.
Stay tuned and I will post results if successful.
Gregg
880 次查看
Heron
This is the same problem that I have already posted as "GDB server closes connection" by Luis Espinal Mar 19, 2020
