I'm using the unmodified demo apps for the FRDM-KE02Z40M board.
Errors:
Debugger Console tab:
monitor selectcore 0
"monitor" command not supported by this target.
continue
The program is not being run.
Console tab:
P&E Semihosting Console
Connection closed by the GDB server.
<Device is being erased and programmed and runs OK standalone, but will not run from debugger connection.>
UPDATE CORRECTION: Device is NOT getting erased OR programmed with Xpresso IDE v11.1.1.
Console info:
IDE v11.0.1. IDE v11.1.1.
What's the problem?
Hi Luis,
I have contacted PEmicro support. Based upon the information I sent them, they confirmed that there seems to be a problem (drivers maybe?), although they could not confirm with my specific FRDM board.
They requested more specific information which I just sent.
Stay tuned and I will post results if successful.
Gregg
