Do not ignore pre-build error
jakub_tymejczyk
How to stop building project if pre-build step fails?
I want to stop building project as soon as pre-build step fails.
To test I added command `false` to pre-build step.
Output is `make[1]: [makefile:211: pre-build] Error 1 (ignored)` but compilation continues. I want to stop process after that.
lpcxpresso_supp
According to the official Eclipse documentation, the main build gets executed regardless the success/failure of the pre-build step - see [1]. I think you might need to invoke your scripts through rules from the actual makefile.
MCUXpresso IDE Support
[1] https://help.eclipse.org/latest/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Freference%2Fcdt_u_prop...
lpcxpresso_supp
