How to stop building project if pre-build step fails?
I want to stop building project as soon as pre-build step fails.
To test I added command `false` to pre-build step.
Output is `make[1]: [makefile:211: pre-build] Error 1 (ignored)` but compilation continues. I want to stop process after that.
Solved! Go to Solution.
According to the official Eclipse documentation, the main build gets executed regardless the success/failure of the pre-build step - see [1]. I think you might need to invoke your scripts through rules from the actual makefile.
MCUXpresso IDE Support
