HI nxp,
I have a question about imxrt595s jlink debugging with MCUXpresso IDE.
after starting debugging, it will not run into our image, and to make sure pause debugging, it stops at address 0x1c04a, from memory map, it seems a boot-ROM address, so I guess for some reasons, it hangs in bootloader, but does not enter into our firmware, even the main entry.
What should I do next, thank you so much.
Hello ShawnBai,
The i.MXRT595 is still in preproduction status and thus public information is limited, so I would need to ask you to please contact your Distributor or FAE and they will be able to provide more assistance.
My apologies for the inconvenience.
