According to your web site, it is not recommended to use LPCXpresso, but MCUXpresso instead. In order to use MCUXpresso, it is necessary to install proper SDK, but LPC15xx is not available as option in SDK builder. The file "MCUXpresso Supported Devices Table (Dec 2019).xlsx" specifies LPCOpen to be used, but I was unable to find and install this SDK.
Please, advice.
Peter
解決済! 解決策の投稿を見る。
The LPC1519 (and other LPC devices) come pre-installed with the MCUXpresso IDE:
No SDK needed.
I hope this helps,
Erich
No SDK needed.
I hope this helps,
Erich
Thank you very much!
Bets Regards,
Peter
