import
import
imrankhan
Hi Forum,
I am trying to import an SDK_2.2.0_MKL14Z32xxx4.mex file into  MCUXpresso IDE to use chipset device MKL14Z32VTF and create a project from the scratch. Since there is no near compatible board for the MKL14xx in the new project creation library. IS there any way one can suggest how can be imported the above file for correct pin muxing, clock etc?
Greatly appreciated. Thank you.
marek-trmac
Hi Imran,
it shall be possible to import configuration from existing MEX file into existing MCU IDE project using:
- right click on the project in Project Explorer and select import from popup menu
- select MCUXpresso Config Tools - Import Configuration (*.mex)
Hope this helps
Marek
Marek
