We are pleased to announce that MCUXpresso Config Tools v12 are now available.
Downloads
- It’s a part of MCUXpresso IDE
- In order to use it with other toolchains, download the installer for all platforms, please login to our download site via:
Please refer to MCUXpresso Config Tools documentation for installation and quick start guides.
For online version, login into MCUXpresso site:
Revision History
12.0
- 12.0
- The product is based on Eclipse 2021-12
- Enabled EcmaScript 6 script engine
- Supported Override outpath of files generated by tools
- Project clonner
- Added support for SDK 2.12
- TEE tool
- i.MX 8ULP applications processor family is now supported:
- Implemented basic XRDC configuration (MRC, MSC, and PAC)
- Additionally implemented Process Identifier, TSM, and SP4SM configuration
- Hybrid templates updated for XRDCs MRC that can be edited by the user and selected by the code region
- Fixes for the KW45 family:
- Fixed the bug where LK1 bit in TRDC_CR is not set when all the GVLD bits are set
- Fixed the bug where setting a lock in Access Templates does not work
- Fixed the bug where setting ID bypass of a master does not set the bit in its MDA register in the Registers view
- Fixes for LPC55S and RT5xxS/6xxS families:
- Fixed the bug where the NSC region is not shown correctly
- Other minor improvements and fixes
- Pins tool
- Added the command to create a function with default routing of pins and signals
- Created the External User Signals view
- Added an option to change pins labels in the package view
- Peripherals tool
- Fixed the problem with "*/" in the string setting or the instance's comment
- Components may add instance of another component if required by the component
- Migration will not change the initialization order
- Clocks tool
- Added an option to override locked values to the Import registers dialog
- Improved behavior of changing global configurations elements in the Functional group properties dialog
- Minor improvements and fixes
- Added support for MEX files in comparison to the Update code dialog
- Overview of Data for Config Tools v12:
- General
- Support of SDK 2.12
- Support of RT1061xxxB/RT1062xxxxB
- Pins tool
- Support of disable states for LPC processors needed to support pins and signals default routing
- Improved labels of expansion headers
- Bugfixes and minor improvements
- Clocks tool
- Peripherals tool
- Register init. Components
- New SEMC register init. component for future integration with memory validation tool
- SDK init. Components
- Improved initialization of MPU on Kinetis and i.MX RT processors via new configuration in Global settings
- TEE tool
- Memory validation tool
- Support of Layerscape LX2/LA families
Community
