Kinetis Bootloader Version 2.0.0
4,003件の閲覧回数
ken_sallings1
I am having trouble with the Kinetis Bootloader Version 2.0.0.
I have a TWR-K65F180M board.
I am using KDS 3.2.
I am using the USB HS with MSD.  I drag and drop a firmware.sb file created from the following command file:
// Define one input file that will be the first file listed
// on the command line. The file can be either an ELF file
// or an S-record file.
sources {
inputFile = extern(0);
// create a section
section (0) {
load inputFile; // load all sections
call inputFile; // jump to entry point
The STATUS file reads "Ready" before I copy the .sb file.
After I copy the .sb file STATUS reads "Transferring" forever.  Any ideas out there?
タグ(1)
3,215件の閲覧回数
ken_sallings1
Jeremy,
Thank you for your support.  Everything is now working.  I had an error when loading the image via the elf file.  When I switched to a binary file and fixed the start address to 0x0000e000, everything worked.  Here is my final command file for anyone that is interested.
sources {
     // create a section
     section (0) {
     erase all;
     load inputFile > 0x0000e000;
     reset;
12 返答(返信)
3,215件の閲覧回数
ken_sallings1
Most everything is now working; my last problem is that when I start my application from the bootloader, I go into the HardFault exception handler.  I have spent all day trying to determine why.  I could really use some help.
3,215件の閲覧回数
jeremyzhou
Hi Ken,
Thanks for your reply.
I'd like to know whether the hard fault interrupt arise when debug the application or not, and what's the kind of operation execute in the application demo?
Ping
3,216件の閲覧回数
ken_sallings1
Jeremy,
sources {
     // create a section
     section (0) {
     erase all;
     reset;
3,215件の閲覧回数
davenadler
Senior Contributor I
Ken, had the same problems. See this thread for some solutions:
https://community.nxp.com/message/843787
3,215件の閲覧回数
jeremyzhou
Hi Ken,
According to your reply, the 0x~0xa000 range of flash area would be occupied by bootloader code.
Next, you should focus on another two modification, the first is linker file of the application demo and the second is the BD file, and I've also illustrated the modified BD file below.
sources {
        # BIN File path
        myBINFile = "xx.bin";
section (0) {
        #1. Erase the internal flash
        erase 0x0000a000..0x0010000;
        #2. Load BIN File to internal flash
        load myBINFile > 0xa000;
        #3. Reset target.
        reset;
Hope it helps.
Ping
3,215件の閲覧回数
ken_sallings1
I can't load anything to address less than 0x0000e000.  When I run the bootloader INFO.txt has the following:
Kinetis Bootloader K2.0.0
System device ID: 0x650083ac
Flash size: 2097152 bytes
Flash range: 0x00000000-0x001fffff
Flash sector size: 4096 bytes
Flash blocks: 4
RAM size: 262144 bytes
RAM range: 0x1fff0000-0x2002ffff
Reserved region 0: 0x00000000-0x0000dfff
Reserved region 1: 0x1fff0000-0x1fff485f
Verify writes: yes
Check reserved regions: yes
Boot config present: no
Peripheral detection timeout: 0 ms
CPU clock: 120000000 Hz
However, I did find in bootloader_config.h that the value is 0x0000a000.  I changed that to 0x0000e000 and I am still having trouble.
3,215件の閲覧回数
jeremyzhou
Hi Ken,
I was wondering if you can share the completely procedure of experiment, then I can replicate the issue on my site.
It can help me to figure out the root cause of the issue.
I'm looking forward to your reply.
Ping
3,215件の閲覧回数
ken_sallings1
I believe that I almost have this solved.
At first, the bootloader was in a sync_wait call forever; it appears that the USB_HID interface code was causing this.  I am not 100% sure about this.  The sync_wait loop went away when I removed the USB_HID support from bootloader_config.h.  Now I discovered that my elftosb command file needed some work.  I am now using this.
sources {
// create a section
section (0) {
//erase 0x0000e000 .. 0x1ffeffff;
erase all;
I believe that it is now failing when my data section is getting loaded.  I am going to modify my command file to not load the data sections.
3,215件の閲覧回数
jeremyzhou
Hi Ken,
In the ~\NXP_Kinetis_Bootloader_2_0_0\NXP_Kinetis_Bootloader_2_0_0\targets\MK65F18, the KBOOT v2.0 has provided two kinds of the bootloader demo, Flashloader and Tower_bootloader, which one do you choose?
Ping
3,215件の閲覧回数
ken_sallings1
I am using tower_bootloader.
3,215件の閲覧回数
ken_sallings1
I have tried tracing this in the debugger, and the device is stuck in a sync_wait call.  Below is the snippet of code:
     // The first receive data request was initiated after enumeration.
     // After that we wait until we are ready to read data before
     // we request more. This mechanism prevents data loss
     // by allowing the USB controller to hold off the host with NAKs
     // on the interrupt out pipe until we are ready.
     if (g_device_composite.hid_generic.hid_packet.isReceiveDataRequestRequired)        {
            // Initiate receive on interrupt out pipe.
            USB_DeviceHidRecv(g_device_composite.hid_generic.hid_handle, USB_HID_GENERIC_ENDPOINT_OUT,
                              (uint8_t *)&g_device_composite.hid_generic.hid_packet.report.header,                                                            sizeof(g_device_composite.hid_generic.hid_packet.report));
     g_device_composite.hid_generic.hid_packet.isReceiveDataRequestRequired = true;        // Wait until we have received a report.           sync_wait(&g_device_composite.hid_generic.hid_packet.receiveSync, kSyncWaitForever);
3,215件の閲覧回数
ken_sallings1
I have gotten further with this.
The transfer is failing to write to flash, because the target memory address is reserved.
