Hi all,
I am a custom board which has a MK22FN128VLH10.
Now I'm trying to update the firmware using Kinetis Bootloader 2.0.
At first I have tested the scenario on FRDM-K22F and everything is O.K.
Next I have done using the custom board as follows:
1. Import led_demo_tower_a000 project from apps\led_demo\MK22F12810\kds on KDS then build it (release).
2. Import tower_bootloader project from targets\MK22F12810\kds on KDS then build it (release).
3. Run tower_bootloader then "FSL Loader" drive appears on Windows.
4. Run KinetisFlashTool on Windows then select "USB-HID" and connect.
5. Click "Update" button then following messages appeared.
Connected to device successfully!
Collecting device information......
Device information is updated!
Start update progress......
Updating image......
Error: Update image failed(kStatusMemoryRangeInvalid).
Update process is stopped by error.
Do you think I have something mistakes or misunderstanding ?
Your any comments would be appreciated.
Hi, Daniel.
Finally I have succeeded to update the firmware!
I needed to modify is_boot_pin_asserted API in hardware_init_K22F128R.c that it should always return false.
It seems the bootloader checks button status on FRDM/Tower boards but our custom board has no button.
Thanks for your help.
Hi shuichiy
You are running Tower_bootloader, If your FSL_Loader gone and appears again, probably your LED demo not update successfully. Did you see the led blinking?
Before you begin the update process, please make sure KinetisFlashTool connected correctly, see below picture.
Then you can update your led demo.
Hi Daniel,
Thank you for your response.
I carefully read the thread then tried again, but the situation has not changed.
I tried to update the firmware using both .bin and Intel hex, updating successfully finished but "FSL Folder" drive comes back promptly.
Here is contents of INFO.TXT in the drive and a bitmap of Flash tool.
If you can add any comments, please let me know.
Hi shuichiy:
Please be aware of the difference of flashloader_loader and flashloader, one is one-shot, the other is always in boot mode. If you are using flashloader, it is normal to stay in boot mode.
Hi Shuichiy:
Please refer to below thread for the procedure.
Setting up Kinetis bootloader on MK22FN128 unsuccessful.
I also copied here:
Please open KBOOT2.0:NXP_Kinetis_Bootloader_2_0_0\NXP_Kinetis_Bootloader_2_0_0\targets\MK22F12810
1 Use tower bootloader:
2 Download this bootloader to your chip, then modify your application code, and relocate it to 0XA000, build and generate the app.bin file.
3. You can use kinetisFlashTool to download your application code, the tool can be found in folder:
NXP_Kinetis_Bootloader_2_0_0\NXP_Kinetis_Bootloader_2_0_0\bin\Tools\KinetisFlashTool\win
After you download the application code successfully, you still can download the new application with the fixed flash bootloader again.
The problem has gone.
After re-copying Kinetis Bootloader 2.0 and rebuild the program, updating succeeds.
Still there's another problem.
Just after updating the firmware (led-demo), once "FSL Loader" drive has gone then appears again at once.
So I seem the bootloader starts again.
I'm thinking about which program has cause of this, bootloader or led-demo...
Maybe the led-demo not update successfully.
