S32V234 how to do communication between cortex A53 and Cortex M4
1,797件の閲覧回数
447825937
Hi ,
Have you find a solution for communicating with A53 and M4?
I have a subject to use M4 for real time control which receive information from image process result on A53 then run real time controller on M4 . I have no idea about the communication part .
Is there any suggestions about that?
with great appreciate .
Thx.
タグ(2)
2 返答(返信)
1,671件の閲覧回数
paulvlase
Hello  askariz askariz,
This community space do not cover the topic you need assistance on.
Please create new NXP support case according to following procedure:https://community.nxp.com/docs/DOC-329745
Hope this helps,
Paul
1,671件の閲覧回数
andrei_skok
All system memory, including System RAM, TCM and externally
connected DDR SRAM is visible to all A53 and M4 cores, thus the simplest
way of communication between the on-chip cores is via shared memory.
However, there is no recommended API to adhere. Customers are free
to select whatever they find most appropriate for their applications.
