APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h: No such file or directory
2,477 次查看
wweir0618
when I run the code:nxpvt_codegen('face_detection_camera_main.m',config);
I meet a problem.as the follows:
../graphs/build-apu-nxp-sa-d/APU_CASCADE_OBJECT_DETECTION_LBP_4.hpp:8:97: fatal error:APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h: No such file or directory
but I find they are in the same folder.can everyone help me?thank you.
4 回复数
2,244 次查看
paulvlase
Hi wweir0618@outlook.com‌,
Can you attach the entire output of the build from Diagnostics Viewer window?
2,244 次查看
wweir0618
Hipaulvlase‌. Thanks for your reply. The entire output of the build is so long, as follows:
>> run_face_detection_camera_main
警告: Target IP Address is not set. Please set the global TARGET_IP_ADDRESS to the IP address of the board
> In run_face_detection_camera_main (line 13)
FFmpeg library already installed
Warning: coder.wref() is treated as coder.ref() when applied on a variable-sized array or a structure with
variable-sized fields.
Warning in ==> UMat_int32 Line: 97 Column: 75
Code generation successful (with warnings): View report
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../msys32/mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../msys32/usr/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../msys32/mingw64/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
Current SDK ROOT is /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk
make[1]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[-]: skipping directory /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_offline/build-x86-gnu-windows-d
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[2]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
apu-kernel-getgraphs.mk: updating apu_cascade_object_detection_lbp_4_apu_process_desc_main.cpp
apu-kernel-getgraphs.mk: updating apu_cascade_object_detection_lbp_4_apu_process_desc_main.cpp_g++.d
  offline/X86 CX apu_cascade_object_detection_lbp_4_apu_process_desc_main.o
  offline/X86 LD apu_cascade_object_detection_lbp_4_apu_process_desc_main.exe  <=  apu_cascade_object_detection_lbp_4_apu_process_desc_main.o /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_offline/build-x86-gnu-windows-d/libacf_offline.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d/object_detection_kernelsacf.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d/optimization_kernelsacf.a
  offline/X86 executing apu_cascade_object_detection_lbp_4_apu_process_desc_main.exe
make[3]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
  apex/clang CX APU_CASCADE_OBJECT_DETECTION_LBP_4__MKDBstub.o
  apex/clang CX APU_CASCADE_OBJECT_DETECTION_LBP_4.o
make[3]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
  apex/clang LD APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.elf  <=  APU_CASCADE_OBJECT_DETECTION_LBP_4.o APU_CASCADE_OBJECT_DETECTION_LBP_4__MKDBstub.o /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d/libacf_target.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d/libapu_common.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d/object_detection_kernels.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d/optimization_kernels.a
  apex/clang READELF APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h
make[2]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[1]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[1]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[-]: skipping directory /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/firmware/build-v234ce-gnu-linux-o
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[5]: Nothing to be done for 'all'.
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Nothing to be done for 'apu_graphs'.
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Nothing to be done for 'apu_graphs_link'.
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'all'.
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'apu_graphs'.
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'apu_graphs_link'.
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[4]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
.C0_headdep.mk: updating nxpvt_CascadeObjectDetector_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_CascadeObjectDetectorLBP-cpp.C0.d
.C0_headdep.mk: updating tinyxml2-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoreader_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoreader-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoinput_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoinput-cpp.C0.d
.C0_headdep.mk: updating nxpvt_utils-cpp.C0.d
.C0_headdep.mk: updating nxpvt_umat_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_opencv_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imwrite_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imshow_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imread_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_convertScaleAbs_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_resize_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_remap_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_peopledetector_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_peopledetector-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_interpolation_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_integral_image_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_image_filters_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_histogram_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_color_conversion_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_arithmetic_w-cpp.C0.d
.C0_headdep.mk: updating gdc_pd_types-cpp.C0.d
.C0_headdep.mk: updating camera_input-cpp.C0.d
.C0_headdep.mk: updating main-cpp.C0.d
.C0_headdep.mk: updating surfCommon-cpp.C0.d
.C0_headdep.mk: updating pointTrackerCore-cpp.C0.d
.C0_headdep.mk: updating opticalFlowFarnebackCore-cpp.C0.d
.C0_headdep.mk: updating mwsurf-cpp.C0.d
.C0_headdep.mk: updating mwminiflann-cpp.C0.d
.C0_headdep.mk: updating mwhog-cpp.C0.d
.C0_headdep.mk: updating mwhaar-cpp.C0.d
.C0_headdep.mk: updating mwfreak-cpp.C0.d
.C0_headdep.mk: updating mwflann-cpp.C0.d
.C0_headdep.mk: updating mwfast-cpp.C0.d
.C0_headdep.mk: updating mwcascadedetect-cpp.C0.d
.C0_headdep.mk: updating mwbrisk-cpp.C0.d
.C0_headdep.mk: updating matchFeaturesApproxNNCore-cpp.C0.d
.C0_headdep.mk: updating features2d_init_mw-cpp.C0.d
.C0_headdep.mk: updating fast_score_mw-cpp.C0.d
.C0_headdep.mk: updating fastHessianDetectorCore-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main_terminate-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main_initialize-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main_emxutil-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main-cpp.C0.d
.C0_headdep.mk: updating extractSurfCore-cpp.C0.d
.C0_headdep.mk: updating extractKAZECore-cpp.C0.d
.C0_headdep.mk: updating extractFreakCore-cpp.C0.d
.C0_headdep.mk: updating extractBRISKCore-cpp.C0.d
.C0_headdep.mk: updating disparitySGBMCore-cpp.C0.d
.C0_headdep.mk: updating disparityBMCore-cpp.C0.d
.C0_headdep.mk: updating detectMserCore-cpp.C0.d
.C0_headdep.mk: updating detectKAZECore-cpp.C0.d
.C0_headdep.mk: updating detectFASTCore-cpp.C0.d
.C0_headdep.mk: updating detectBRISKCore-cpp.C0.d
.C0_headdep.mk: updating cgCommon-cpp.C0.d
.C0_headdep.mk: updating agast_score_mw-cpp.C0.d
.C0_headdep.mk: updating HOGDescriptorCore-cpp.C0.d
.C0_headdep.mk: updating CascadeClassifierCore-cpp.C0.d
  arm64/gnu/optimized CX CascadeClassifierCore-cpp.o
  arm64/gnu/optimized CX HOGDescriptorCore-cpp.o
  arm64/gnu/optimized CX agast_score_mw-cpp.o
  arm64/gnu/optimized CX cgCommon-cpp.o
  arm64/gnu/optimized CX detectBRISKCore-cpp.o
  arm64/gnu/optimized CX detectFASTCore-cpp.o
  arm64/gnu/optimized CX detectKAZECore-cpp.o
  arm64/gnu/optimized CX detectMserCore-cpp.o
In file included from ../HOGDescriptorCore.cpp:15:0:
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/cgCommon.hpp: In instantiation of 'void copyToMatBGR_RowMaj(ImageDataType*, ImageDataType*, int, int, int) [with ImageDataType = unsigned char]':
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/cgCommon.hpp:270:41:   required from 'void cArrayToMat_RowMaj(const ImageDataType*, int, int, bool, cv::Mat&) [with ImageDataType = unsigned char]'
../HOGDescriptorCore.cpp:74:67:   required from here
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/cgCommon.hpp:93:103: warning: unused parameter 'channels' [-Wunused-parameter]
 void copyToMatBGR_RowMaj(ImageDataType *src, ImageDataType *dst, int numRowsInBlock, int numCols, int channels)// remove channels from here
In file included from ../detectBRISKCore.cpp:15:0:
../detectBRISKCore.cpp:97:60:   required from here
In file included from ../detectFASTCore.cpp:14:0:
../detectFASTCore.cpp:86:67:   required from here
../detectMserCore.cpp: In function 'void regionsToPointsArrayRM(std::vector<std::vector<cv::Point_<int> > >&, int32_T, int32_T*, int32_T*)':
../detectMserCore.cpp:61:66: warning: unused parameter 'numTotalPts' [-Wunused-parameter]
 void regionsToPointsArrayRM(vector< vector<Point> > &in, int32_T numTotalPts,
In file included from ../detectKAZECore.cpp:14:0:
../detectKAZECore.cpp:34:73:   required from here
In file included from ../detectMserCore.cpp:12:0:
../detectMserCore.cpp:162:67:   required from here
  arm64/gnu/optimized CX disparityBMCore-cpp.o
  arm64/gnu/optimized CX disparitySGBMCore-cpp.o
  arm64/gnu/optimized CX extractBRISKCore-cpp.o
  arm64/gnu/optimized CX extractFreakCore-cpp.o
  arm64/gnu/optimized CX extractKAZECore-cpp.o
  arm64/gnu/optimized CX extractSurfCore-cpp.o
  arm64/gnu/optimized CX face_detection_camera_main-cpp.o
  arm64/gnu/optimized CX face_detection_camera_main_emxutil-cpp.o
In file included from c:\users\stefan\appdata\roaming\mathworks\matlab-add-ons\toolboxes\nxp_vision_toolbox_for_s32v234\internals\src\include\nxpvt_cascadeobjectdetectorlbp.hpp:31:0,
                 from ../face_detection_camera_main.cpp:4:
../graphs/build-apu-nxp-sa-d/APU_CASCADE_OBJECT_DETECTION_LBP_4.hpp:5:97: fatal error: APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h: No such file or directory
 #include <APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h> //APU load associated with this process
compilation terminated.
make[3]: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/helpers.mk:174: face_detection_camera_main-cpp.o] Error 1
make[3]: *** Waiting for unfinished jobs....
In file included from ../disparityBMCore.cpp:13:0:
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp: In function 'void copyClipAndCastBMRM(int16_T*, real32_T*, mwSize, mwSize, mwSize, mwSize, mwSize, int16_T, mwSize)':
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp:183:9: warning: unused parameter 'numInRows' [-Wunused-parameter]
  mwSize numInRows, int16_T invalidValue, mwSize borderWidth)
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp: In instantiation of 'void copyAndPadRM(T*, T*, mwSize, mwSize, mwSize, mwSize, mwSize) [with T = unsigned char; mwSize = long unsigned int]':
../disparityBMCore.cpp:96:79:   required from here
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp:44:9: warning: unused parameter 'numInRows' [-Wunused-parameter]
  mwSize numInRows)
In file included from ../disparitySGBMCore.cpp:13:0:
../disparitySGBMCore.cpp:103:79:   required from here
  mwSize numInRows)
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp: In instantiation of 'void copyAndClipRM(T*, T*, mwSize, mwSize, mwSize, mwSize, mwSize, T, mwSize) [with T = float; mwSize = long unsigned int]':
../disparitySGBMCore.cpp:139:37:   required from here
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp:112:9: warning: unused parameter 'numInRows' [-Wunused-parameter]
  mwSize numInRows, T invalidValue, mwSize borderWidth)
In file included from ../extractBRISKCore.cpp:14:0:
../extractBRISKCore.cpp:147:60:   required from here
In file included from ../extractKAZECore.cpp:11:0:
../extractKAZECore.cpp:124:73:   required from here
make[3]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[2]: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/platforms/coordinator.mk:57: all] Error 2
make[2]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[1]: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/sub.mk:74: allsub] Terminated
make[1]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/platforms/coordinator.mk:57: allsub] Error 2
thank you very much!
2,244 次查看
paulvlase
Hi wweir0618@outlook.com‌,
I don't understand why it fails.
Could you attached the codegen folder as a zip archive?
When you write a message you have "Use advanced editor" option to attach files.
2,244 次查看
wweir0618
Hi, paulvlase
Here is the  zip archive, thanks!
