How to run batch before the make file auto generated
3,926件の閲覧回数
wlee
i am using S32K146 and compiler it using the S32DS for ARM and make file is auto generated. In S32DS pre-build steps, i will trigger a batch file to generate a out folder and generated few c file inside it. For the first time, the out folder and debug folder is not exist and when the make file search for the c files it don't include the auto generated c files.
My question is how to trigger my batch file before the S32DS generate the make file? any place i can configure? else the compilation will fail.
2 返答(返信)
3,830件の閲覧回数
mariuslucianand
Hi wlee@lear.com‌,
This community space do not cover the topic you need assistance on.
Please create new thread on the https://community.nxp.com/community/s32/s32ds  community space or new NXP support case according to following procedure:https://community.nxp.com/docs/DOC-329745.
Hope this helps,
Marius
2,160件の閲覧回数
Guth55434
The solution worked for me thanks to the community and the members for the solution.
MyGiftCardSite
