We use Freescale SDK for LS1021A processor and we would like to add "zdump" command into our Root File System.
Which Yocto package should we use?
The SDK contents "tzcode-native" package, but it is possible to run on only the host machine.
Victor
已解决! 转到解答。
You must be working with a damaged or improperly installed SDK, incorrectly setup environment or unsupported host distribution. Install your SDK afresh, make sure you followed all installation instructions:
This is how it looks with a properly installed SDK:
platon@platon-ws:~/work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr$ bitbake -s | grep glibc
glibc :linaro-2.20-r2014.11
glibc-initial :linaro-2.20-r2014.11
glibc-locale :linaro-2.20-r0
glibc-mtrace :linaro-2.20-r0
glibc-scripts :linaro-2.20-r0
nativesdk-glibc :linaro-2.20-r2014.11
nativesdk-glibc-initial :linaro-2.20-r2014.11
nativesdk-glibc-locale :linaro-2.20-r0
I was able to insert "zdump" utility in our root file system when I added "eglibc-utils" in the IMAGE_INSTALL += line, although even the "eglibc-utils" package was not in the "bitbake -s" list.
zdump is part of glibc Yocto package
Platon
Thank you for the answer Platon,
I did not find “glibc” package in the SDK. Please see the bitbake response below:
eglibc :linaro-2.19-r2014.04
eglibc-initial :2.19-r0
eglibc-locale :2.19-r0
eglibc-mtrace :2.19-r0
eglibc-scripts :2.19-r0
nativesdk-eglibc :linaro-2.19-r2014.04
nativesdk-eglibc-initial :2.19-r0
nativesdk-eglibc-locale :2.19-r0
I verified that “zdump” command is also NOT included in the “eglibc” package.
Could you specify which Yocto package contents the “zdump” command?
Victor
Thank you for your support, Platon.
You are right. We use the Freescale-Linux-SDK-for-LS1021A-IOT-Rev2-v0.4-20150907-yocto.iso version of SDK.
I also found the “zdump” utility in the eglibc (linaro-2.19-r2014.04) package.
Victor Mazin
