VPP plugin with strongswan feature
894 次查看
jackho
As I know, VPP 22.10 version will support strongswan plugin, which is called VPP-SSwan, and the detail info as below link:
https://networkbuilders.intel.com/docs/networkbuilders/fd-io-vpp-sswan-and-linux-cp-integrate-strong...
Do you plan to upgrade VPP to the new version for the LSDK platform?
Jack Ho
862 次查看
jackho
Hi @yipingwang
Thanks for your information.
May I know what is the difference between LSDK and LLDPUG release?
Does that mean now will use LLDPUG instead of LSDK in the future?
BR,
Jack Ho
884 次查看
yipingwang
Please refer to NXP latest LSDK release for Layerscape https://www.nxp.com.cn/docs/en/user-guide/LLDPUG_RevL6.1.22_2.0.0.pdf
VPP version is as the following.
VPP v23.02 build with DPDK 22.11.
863 次查看
jackho
Hi @yipingwang
BR,
Jack Ho
859 次查看
yipingwang
LLDPUG is based on Yocto, LSDK is based on flex-builder.
LLDPUG is newer than LSDK.
LLDPUG will replace LSDK in feature.
