Fetch failed when to try real-time-edge v2.6 for ls1028;
ソリューションへジャンプ
6,096件の閲覧回数
xinliwang
Hi @yipingwang
I got an error when I try to bitbake nxp-image-real-time-edge v2.6 for ls1028 board;
for the url I try it on my browser and it pops 404 error like down below:
http://etherlab.org/download/ethercat/
it doesn't have this page?
タグ(1)
5,792件の閲覧回数
Irene
NXP Pro Support
NXP Pro Support
  The tarball that you need can be found at:
www.nxp.com/lgfiles/updates/other/ethercat-1.5.2.tar.bz2
Irene
8 返答(返信)
5,793件の閲覧回数
Irene
NXP Pro Support
NXP Pro Support
Irene
6,065件の閲覧回数
Irene
NXP Pro Support
NXP Pro Support
Are you using the NXP release or something upstream?  are you following the steps outlined in the attached document which can be found on the nxp.com website.
6,049件の閲覧回数
xinliwang
Hi @Irene
Yes, I just follow the step as reference menu told.
Did you check the link I post? I think there is no way i can fetch if the link doesn't work.
6,076件の閲覧回数
Irene
NXP Pro Support
NXP Pro Support
Let me look into this issue.
6,003件の閲覧回数
xinliwang
Hi, @Irene
Any ideas for my problem?
5,939件の閲覧回数
Irene
NXP Pro Support
NXP Pro Support
Which release are you used ? I dont find nxp-image-real-time-edge in our 6.1.22 release.
5,874件の閲覧回数
xinliwang
@Irene
I'm not the only person who has the same issue.
Please check the link https://github.com/nxp-real-time-edge-sw/yocto-real-time-edge/issues/7
5,923件の閲覧回数
xinliwang
Hi, @Irene
I don't get it what do you mean that you dont find nxp-image-real-time-edge”?
According to the reference menu RTEDGEYOCTOUG_Rev2.6 on page 8, Yocto Project build uses the bitbake command.
