Hi and happy new year,
I searche a board that immplement the trutzone technologie with TZC400.
I want to use the NSAID utility and I would like to know if LS1043 board reference allows this TZC400 utilities.
If yes could you please give me the NSAID implementation or that peripherals can uses NSAID(exemple: DMA, each CPU......)
Letailleur Jérôme
解決済! 解決策の投稿を見る。
Look at attached file. It is NXP SDK 0.5 Reference Manual. See information about Trustzone in the file.
Pavel
Pavel
Hi Pavel,
I had read the datasheet after my post and I am sad because the controller used TZASC380. This controller does not NSAID feature.
It is necessary that I use the TZC400 controller for trustzone protection.
Thanks you very much for your help.
PS: if freescale works on TZC400 and NSAID, I think that is interessant that each CPU have unique NSAID.
