I am configuring LS1021A in RMII mode. Initialization steps in Reference manual says -
Set MIIMADD = 0x0000_nn11 (TBICON, where nn=TBIPA)
When read through reference manual, I could understand that - In order to access any TBI register, I have to load it's address in MIIMADD register. But I don't understand what value I should assign to TBIPA.
TBI's Physical address is stored in TBIPA register.
How can I know TBI's Physical address?
解決済! 解決策の投稿を見る。
The reason we have TBI registers mentioned in the initialization steps (for MII, RMII and RGMM) is because the elastic FIFO reset logic is actually included in the internal TBI Phy logic. Hence a reset of the TBI Phy was added to the eTSEC/dTSEC recommended initialization sequence to ensure no "garbage" data would reside in the elastic FIFO during the controller's initialization.
We will add additional note in the next RM release to clarify this.
For eTSEC1 the TBIPA value should be non-zero and distinct from external PHYs addresses (if any).
For eTSEC2 and eTSEC3 the TBIPA value can be any in range 1-31.
Note that TBI PHY registers have to be accessed by means of MDIO registers belonging to the configured eTSEC.
For eTSEC2 MDIO range starts at 2D6_4000 address offset
For eTSEC3 MDIO range starts at 2DA_4000 address offset
Means, Do I have to ignore these steps?
Additionally, If I have to access TBI registers, I will have to load TBIPA value... So what should I load it?
Or you mean to say TBI is not at all relevant to MII, RMII and RGMII modes? Then where it is required?
Please see corrected response.
Thanks for that... It resolved some confusion...
But is that means, Instead of MIIMADD registers mentioned in Initialization sequence, should I use eTSEC_MDIO_MIIMADD and so on?
Or simply follow the initialization sequence as it is and after init, use eTSEC_MDIO_MIIMADD?
Correct, eTSECn_MDIO_MIIMADD
mmm... Let me reframe the question...
Do I need to use eTSEC_MDIO_MIIMADD in initialization seqeuence?
Yes - see note in the first response.
