Remove Login prompt while working with LS1043 evolution board
511件の閲覧回数
dibyarekha
Hi All,
I'm trying to figure out how to disable the following login prompt after the kernel boots:
QorIQ SDK POC (Proof of Concept) 4.0.4 ls1043ardb ttyS0
ls1043ardb login:
I want my application should run automatically without asking for login
I am using ubuntu 20.04
450件の閲覧回数
dibyarekha
Hi @LFGP ,
I found the solution myself.
add  “-a root “ in ExecStart variable in serial-getty@.service file in following path
/sources/poky/meta/recipes-core/systemd/systemd-serialgetty/serial-getty@.service
ExecStart=-/sbin/agetty -a root -8 -L %I @BAUDRATE@ $TERM
3 返答(返信)
479件の閲覧回数
LFGP
You can use the passwd command.
i.e.
$ sudo passwd -d my_username
451件の閲覧回数
dibyarekha
Hi @LFGP ,
438件の閲覧回数
LFGP
Very good solution @dibyarekha, thanks for share it
