MC high priority command management
1,556件の閲覧回数
dmitri_lechtchinski
According to DPAA2UM, the MC management command portal command includes "P" field for sending commands with high priority.
However from my understanding, if a specific client sets this to '1' for its commands, it can starve other clients which are trying to send commands with low priority.
Is it possible to disable or to manage usage of this field on system-wide level?
Thank you,
Dmitri
タグ(1)
4 返答(返信)
1,520件の閲覧回数
andrei_skok
Dear Dmitri
This "P" bit field is used to specify High priority commands.So this option bit should be used with responsibility (in order to not starve other low priority commands...) This is a feature and it is the "user responsibility" to manage high priority commands vs low priority ones (according to their needs).For example if one specific command is very important and time critical, then that command can be marked as "High Priority" with this option bit.So that means if this option is not used, then it is equivalent as it would be disabled...It is user responsibility to manage High priority commands.Why  would you like to disable it? Or how exactly would you like to be used at system-wide level? Can you provide more details about the usecase in order to understand this request?
1,516件の閲覧回数
dmitri_lechtchinski
Assume we have a hypervisor OS with both safety-critical and non safety-critical partitions running on different cores, and each one uses its own MC portal.
So in this scenario, if a non safety-critical partition "decides" to overflow its portal with high priority commands, this could potentially starve a safety critical partition's functionality.
We are looking for a solution for preventing this from happening, assuming we have little or no control over the non safety-critical partition's behavior.
Thank you,
Dmitri
1,543件の閲覧回数
andrei_skok
Could you please clarify which command / register / field / chapter /DPAA2UM document you are talking about?
1,540件の閲覧回数
dmitri_lechtchinski
Document: DPAA2UM Rev 42
Chapter: 5.5 - Management command portal definition
Field: P - Priority (bit 15)
