LS1046A-RDB w/ 10GBase-T SFP+ module
yutaka_ando
Has any 10GBase-T SFP+ module been tested with LS1046A-RDB board?  If yes, is this module compatible for Cisco or Intel?
ufedor
This is the SFP module we use for 10GBase-T (testing with Spirent and our development boards).
http://a.co/15APKxT
ufedor
Please refer to the QorIQ LS1046A Reference Design Board Getting Started Guide, Rev. 3.
The LS1046ARDB hardware kit contains:
Finisar FTLX8571D3BCL SFP+ transceiver
yutaka_ando
Hello ufedor
Thank you for the comment.
The Finisar FTLX8571D3BCL SFP+ transceiver supports 10GBase-SR/SW which uses optical fiber cable.
I am asking about SFP+ module supports 10GBase-T using copper cable.
There are many 10GBase-T SFP+ modules in the market.
https://www.amazon.com/s?k=10GBase-T+SFP%2B&ref=nb_sb_noss_2
Some modules say "compatible for Cisco" and others say "compatible for Intel", "for Juniper" etc.
So I would like to know if any 10GBase-T SFP+ module have been tested on our evaluation board + LSDK.
Best regars,
Ando
ufedor
http://a.co/15APKxT
