LS1028A Serdes Lane A Phy change
718 次查看
mkraj
Dear NXP expert
1. Due to more ethernet port requirement, Planning to change SerDes lane A SGMII PHY with Microchip SGMII 5 port switch KSZ9477S.  Is it require any major. Is it require any major software change?
2. We are not using IEEE1588 or RGMII interfaces , Still is it required to give EC1_GTX_CLK125 input reference clock?
With Regards
Krishnam Raju M
667 次查看
yipingwang
[1] Treat it as a PHY operating over the SGMII Interface. The Switch will direct any MDIO mgmt. to the appropriate port based on the PHY ADDR used.
[2] See AN12028 for the recommended termination of unused signals.
637 次查看
mkraj
Dear  yipingwang
Thank you.
With Regards
Krishnam Raju m
668 次查看
yipingwang
