LS1021A Audio Issue
LS1021A Audio Issue
1,219件の閲覧回数
brillyckuriakos
We are facing issues while testing audio in the LS1021aiot reference board.The audio record as well as audio playback is not working for us.
Test Environment Info
Reference Board : LS1021A-IOT
SDK Version : 1.8
CPU: Freescale LayerScape LS1021E, Version: 1.0, (0x87081110)
Clock Configuration:CPU0(ARMV7):1000 MHz, Bus:300  MHz, DDR:800  MHz (1600 MT/s data rate)
Build Image  : fsl-image-fsl-image-minimal + alsa utils
Issue
As per the schematics, the audio in interface is
Audio line in -------->sgtl5000------>SAI2 rx
and the audio out connections are like,
SAI2 tx------> sgtl5000-----> Audio line out
By default, the audio codec is set as the master and we could observe the Bit clock as well as frame sync while probing the signals CODEC2_CLK and CODEC2_FS.
From the board console,
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: FSLVF610TWRBOAR [FSL-VF610-TWR-BOARD], device 0: HiFi sgtl5000-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #
0
# arecord -l
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevice #0: subdevice #0
# aplay test.wav
Playing WAVE 'test.wav' :Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
playback write error (DMA or IRQ trouble?)
aplay: pcm_write:1939:write error: Input/output error
[1]+  Done(1)                    test.wav
While doing playback and probing the signal CODEC2_TXD, we couldnt find any data signal.
We have tested the audio record also, But except the header no audio data is being recorded and the record file size remains 44 bytes always.
(Note : For testing the arecord, We have tried mounting the R2 and R505)
タグ(4)
2 返答(返信)
973件の閲覧回数
yipingwang
Hello Brilly C Kuriakose,
According to your log, it looks that RCW and SAI audio driver are configured correctly.
Would you please send your Kernel configuration file and dts file to me to do more investigation?
Yiping
973件の閲覧回数
brillyckuriakos
Hello Yiping,
Thanks for your response..
Attached is the dts,  dtsi file and the kernel config files.
Thanks & Regards,
Brilly
