How to config 100Gbps port on LX2160ARDB
982 次查看
Vaderpucong
I want to use pktgen to test 100Gbps port on LX2160A, but i have no way to instance a 100Gbps port.Is there a way?
840 次查看
yipingwang
LX2160AQDSRM is NXP Confidential Proprietary and can only be provided under non-disclosure agreement (NDA).
You could contact your local FAE to require this document.
5 回复数
963 次查看
yipingwang
You could configure RCW[SRDS_PRTCL_S1] to support 100G Ethernet port on LX2160A, please refer to "26.1.4 SerDes options" in LX2160A Reference Manual for details.
LX2160ARDB only supports 10G,25G,40G.
LX2160AQDS supports 100G port, you need to use M8 card.
930 次查看
Vaderpucong
Hello, I don't know how to modify it. Could you please provide a patch to enable a 100G port?
915 次查看
yipingwang
On LX2160ARDB 100G port is not supported.
If you are doing development on your custom board, you could refer to the source code of LX2160AQDS.
864 次查看
Vaderpucong
I can not find LX2160AQDS at website. Have a link to it?
841 次查看
yipingwang
