Debugging LS1046 DDR4 with tools codewarrior
Hmc510
My board NG in BL2 init step.so I try to refer "QCVS_DDR_User_Guide" Debugging LS1046 DDR4 with tools codewarrior.
I saw a DDR struct "ddr_raw_timing" in my atf project ddr_init.c and it also appears in the document "QCVS_DDR_User_Guide: Click the Generate Processor Expert Code icon. ddr_init1.c".
but nothing happened when I click the Generate Processor Expert Code icon In my ls1046 CW project, and just have this files:
Am I using it incorrectly?
I haven't used DDR validation yet. codewarrior.whether it needs JTAG  debugging?
khushbur
Hi @Hmc510
Looks like your ddr-init code is generated successfully.
What tools are used to connect 1046 boards? Please provide the purchase address?
You can use Codewarrior TAP to connect with board. Below is a link
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/run-control-d...
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/layerscape-processors/ls...
 DDR validation in codeWarrior, does it  need to purchase additional licenses?
The validation feature of QCVS is licensed as per the CW4NET licensing tiers.
To purchase a license, use the link, www.freescale.com/cw4net.
Khushbu
khushbur
Hi @Hmc510
    Can you please raise new tickets for this new issue and close this one. It will help us in managing tickets.
Khushbu
khushbur
Hi @Hmc510
Khushbu
Hmc510
Thank you for your answer.
I have prepared the test tool, But there seems to be some problems.
Can you give me some suggestions?
Hmc510
2GB chip: MT40A1G16KD-062E:E.  x5.
4 ships for 8G, 1 chip for ECC.
ls1046afrwy
CW Version: 11.5.0
and I want to config it as 1.8G
my current atf code:
more questions
What tools are used to connect 1046 boards? Please provide the purchase address.
and use the  DDR validation in codeWarrior, does it  need to purchase additional licenses?
