CodeWarrior® TAP without CodeWarrior software?
969 次查看
miha_at_work
Hello.
Is there some way to use CodeWarrior TAP for debugging device based on LS2084 using only open source or low cost software. CodeWarrior is very expensive for us.
6 回复数
819 次查看
miha_at_work
So how about GDB?
819 次查看
ufedor
CodeWarrior TAP supports network port 2345 used by GDB to control the TAP.
819 次查看
miha_at_work
Is TAP compatible with GDB? Will it stable work with GDB?
819 次查看
ufedor
The GDB is not an NXP product and it is not officially supported.
Please use NXP Community to find additional information.
819 次查看
miha_at_work
Ok. Thank you.
819 次查看
ufedor
Please check tools from other vendors: Lauterbach, Wind River, Green Hills.
