Is there a "how to" guide for building the bootloader firmware for the LS1046ARDB from within Codewarrior and flashing it? An appnote perhaps? I can't seem to find anything.
Thanks in advance.
已解决! 转到解答。
Hello, Thank you for contacting the Technical Support Team,
I hope that this email finds you well,
In the following link you can find the Application Note AN12081 "RAM Boot using CodeWarrior on LS1046ARDB", where at section 5 you can find the booting process with an SD Card.
Hector Villarruel
Hector Villarruel
