Content originally posted in LPCWare by IanB on Tue Dec 23 13:40:49 MST 2014
Can anyone beat 17 different error messages when trying to get the LPC Link to communicate with a recalcitrant project?
Does anyone have any idea what the problem might have been?
Here they all are:
02: Failed on connect
Invalid emulator index - get list of available emulators.
31: No connection to emulator device
Flash driver "Uninit" return code: 0x0
15: Target error from Commit Flash write
Cannot halt processor
15: Target error from Read register
Cannot access core regs when target running
(crt_emu_lpc11_13_nxp) terminating on communication loss: Pipe has been closed by GDB.
invalid ID for processor
Emu(0) Conn&Reset Was: None, DpID: BB11477. Info: LPCLINK
MEM-AP is not selected
15: Target error from Commit Flash Write
Cannot complete transaction, even after slowing speed
15: Target error from Set break/watch
Unable to set an execution break - no resource available.
11: Target error from Reset: (null)
15: target error from Register access
Terminate/Disconnect All is not enabled
Reason:
To terminate debug sessions, first select a debug session in the Debug View and then select Terminate again
10: Could not start execution from stop
(crt_emu_lpc11_13_nxp) terminating due to loss of debug control
15: Target error from Write register
16: Target error from status-Poll
Bad ACK returned from status - wire error.
Failed to execute MU command:
-break-insert -t -f main
Error message from debugger back end:
Could not fetch register "xpsr"; remote failure reply 'E22'
Error from StubRegisterDisplayCoreAll: -interpreter-exec console "mon register_display_core
at com.crt.dsfdebug.dsf.commands.MIStubCommandBase.getResult(unknown source)
at com.crt.dsfdebug.dsf.commands.MIStubCommandWrapper.getResult(Unknown Source)
at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxThread.process
at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxThread.run
'Interrupt monitor job' has encountered a proble,
An internal error occurred during "Interrupt monitor job".
